[mapguide][MG210][Modified] Fix more server leaks
Walt Welton-Lair
walt.welton-lair at autodesk.com
Wed Apr 12 12:47:06 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG210
Type:
Defect
Artifact ID:
MG210 (Fix more server leaks)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Testing Notes set to new value:
Ran web-tier tests on open source server (934/934 passed).
-- Developer Notes set to new value:
There are also some memory leak fixes that have been made to FDO. I will pass along these fixes to the FDO team (via a defect).
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
