[mapguide][MG214][New] Build_oem.sh shell script is upadated.
Vishal Bangia
vishal.bangia at autodesk.com
Wed Apr 12 16:30:01 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG214
Type
Enhancement
Artifact ID
MG214 (Build_oem.sh shell script is upadated.)
Reported by
Vishal Bangia
vishalbangia (vishal.bangia at autodesk.com)
New artifact details:
- Justification set to new value
Fixed:
The help option did not work. Additional reasons are below.
1) Error stoppage is crucial as it offers the end user who builds the project from scratch an idea that a component failed to build.
2) Modular scripting approach which makes it very readable and easy to support/ modify. It is very simple to expand the script if we should choose to add more customization options at a later date.
3) Less lines of code ..:)
4) The script is now much in line with composite build scripts that build a variety of components. e.g. dbxml which builds pathan, db , xquery etc.
Note: There are no changes in the way the script is used. To access any new functionality please use the --help option.
- Artifact created
- Priority set to new value
P2
- Summary set to new value
- Documentation Notes set to new value
No Changes
- Submission Reviewed set to new value
No
- Description set to new value
The build_oem.sh shell script is upadated to
do the following.
1)Stops if an error occurs in any of the Oem component builds.
2)Offers a clean option to clean out the build for all the Oem compoenents.
3) An error with the --help option is fixed.
- Developer Notes set to new value
build_oem.sh --clean
is a new option that offers the ability to clean all the Oem components that are built by the script.
- Artifact Status set to new value
New
- Testing Notes set to new value
tested on Linux RH3 / FC4
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
