[mapguide][MG214][Modified] Build_oem.sh shell script is updated.
Vishal Bangia vishal.bangia at autodesk.com
Wed Apr 12 17:38:58 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG214
Type:
Enhancement
Artifact ID:
MG214 (Build_oem.sh shell script is updated.)
Modified by:
Vishal Bangia
vishalbangia (vishal.bangia at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
The build_oem.sh shell script is upadated to
do the following.
1)Stops if an error occurs in any of the Oem component builds.
2)Offers a clean option to clean out the build for all the Oem compoenents.
3) An error with the --help option is fixed.
New value:
do the following.
1)Stop if an error occurs while building any of the Oem components.
-- Summary changed:
Old value:
Build_oem.sh shell script is upadated.
New value:
-- Developer Notes set to new value:
Old value:
build_oem.sh --clean
is a new option that offers the ability to clean all the Oem components that are built by the script.
New value:
Additonally, the options --clean <lib> --build <lib> which allows the ability to clean/build a single oem component was removed as I couldnt  find a use case for adding it in. Should anybody feel that functionality is required, please do email me and it can be added in.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
