[mapguide][MG206][Modified] WFS/WMS Unit Tests Operations Are Timing Out
Trevor Wekel
trevor.wekel at autodesk.com
Wed Apr 12 19:01:16 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG206
Type:
Defect
Artifact ID:
MG206 (WFS/WMS Unit Tests Operations Are Timing Out)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- Resolution Description set to new value:
Old value:
Commented the WFS/WMS operations for now.
New value:
Disabled the WFS/WMS operation tests for now.
-- Review Comments set to new value:
These tests should be enabled once the root cause has been found.
-- Submission Reviewed changed:
Old value:
No
New value:
Yes
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
