[mapguide][MG188][Modified] Script error when changing scale before map is loaded in AJA...
Alain Lebatard alain.lebatard at autodesk.com
Wed Apr 12 20:03:08 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG188
Type:
Defect
Artifact ID:
MG188 (Script error when changing scale before map is loaded in AJAX viewer)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
-- Target milestone set to new value:
1.0.1
-- Resolution Description set to new value:
In addition to protect against action from scale slider, this submission also protects against execution of other map command and interaction with the map as well before the map is initialized.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
