[mapguide][MG218][New] Updated comments in header files.
Philip Sharman
philip.sharman at autodesk.com
Thu Apr 13 18:15:36 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG218
Type
Defect
Artifact ID
MG218 (Updated comments in header files.)
Reported by
Philip Sharman
philipsharman (philip.sharman at autodesk.com)
New artifact details:
- Resolution set to new value
Submitted
- Defect Severity set to new value
Low
- Documentation Notes set to new value
- Removed information about future plans from MgUserInformation
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\System\UserInformation.h
- Marked some methods as internal.
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Services\BaseServiceDefs.h
- Moved this to the exceptions module:
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Exception\InvalidOperationVersionException.h
- This was marked NOT_EXPOSED_module, but it should be public.
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Services\ImageFormats.h
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Services\RasterTypes.h
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Services\UnitType.h
- Fixed incorrect parameter name in comments for GetWfsFeature
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Services\FeatureService.h
- Fixed incorrect parameter name in comments for QueryFeatures
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Services\RenderingService.h
- Fixed an incorrect <c> tag in the comments of SetResource
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Services\ResourceService.h
- Corrected \site to \link in EnumerateGroups
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Services\Site.h
- Added description for top, left, right, and bottom parameters of MgPlotSpecification
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Services\PlotSpecification.h
- Added \brief tag to
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Net\AceStreamHelper.h
- Fixed bug 707203; clarified that the class name in MgSelection::Contains() is not optional.
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\MapLayer\Selection.h
- Added \brief and \remarks etc in various places
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Services\FeatureInformation.h
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Geometry\Region.h
- Added a summary comment to
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Exception\LengthException.h
- Marked MgPageSizeUnits internal.
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Controller\DwfController.h
- Marked MgMappingServiceOpId as internal
C:\OSGeo+Perforce\mapguide\MgDev\Common\Service\Services\MappingDefs.h
- Description set to new value
Made various fixes to the comments.
This only affects the Web API Reference documentation.
Checked that WebTier.sln still builds correctly.
- Platform set to new value
All
- Target milestone set to new value
1.0.1
- Artifact Status set to new value
New
- Version set to new value
1.0.0
- Artifact created
- Resolution Description set to new value
Fixed.
- Steps to Reproduce set to new value
Build the Web API Reference.
- Subcomponent set to new value
Web API
- Component set to new value
Web Server Extensions
- Summary set to new value
- Submission Reviewed set to new value
No
- Operating system set to new value
All
- Priority set to new value
P5
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
