[mapguide][MG219][New] Fix MapAgent memory leaks
Walt Welton-Lair walt.welton-lair at autodesk.com
Fri Apr 14 04:39:24 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG219
Type
 Defect
Artifact ID
 MG219 (Fix MapAgent memory leaks)
Reported by
 Walt Welton-Lair
 waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Component set to new value
  Web Server Extensions
- Steps to Reproduce set to new value
  - run the MapAgent in fast CGI mode
- run the web tier unit tests
- do a CRT dump of leaked objects
- Subcomponent set to new value
  Map Agent
- Priority set to new value
  P1
- Platform set to new value
  All
- Summary set to new value
- Defect Severity set to new value
  Critical
- Artifact Status set to new value
  New
- Description set to new value
  The MapAgent leaks memory.  This is particularly bad in the case of fast CGI, where the agent is expected to remain in memory for a long time and handle many requests.
- Operating system set to new value
  All
- Artifact created
- Version set to new value
  1.0.0
- Target milestone set to new value
  1.0.1
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
