[mapguide][MG220][New] Broken images in surround Color Picker when transparency sel...
Alain Lebatard
alain.lebatard at autodesk.com
Fri Apr 14 12:48:26 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG220
Type
Defect
Artifact ID
MG220 (Broken images in surround Color Picker when transparency selected)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Version set to new value
1.0.0
- Artifact created
- Defect Severity set to new value
High
- Steps to Reproduce set to new value
Open viewer
Buffer command
Click on the button to set the background color
Make sure "100% transparent" is selected
==> broken images alongside the 3 color value edit controls
- Description set to new value
In the color picker, when "100% transparency" is checked, the image associated with each the 3 spin edit controls is broken
- Summary set to new value
- Platform set to new value
All
- Component set to new value
Web Server Extensions
- Subcomponent set to new value
Viewer API
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
