[mapguide][MG221][New] Color picker spin controls active although appearing disable...
Alain Lebatard
alain.lebatard at autodesk.com
Fri Apr 14 13:12:16 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG221
Type
Defect
Artifact ID
MG221 (Color picker spin controls active although appearing disabled)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Version set to new value
1.0.0
- Description set to new value
When "100% transparent" is checked the spin-edit control are disabled, but the spin arrows are still active.
- Summary set to new value
- Artifact Status set to new value
New
- Subcomponent set to new value
General
- Component set to new value
Web Server Extensions
- Artifact created
- Defect Severity set to new value
Medium
- Steps to Reproduce set to new value
Open a web layout in the viewer
Buffer command
Click to set the background color
Check "100% transparent"
==> Spin arrows look disabled but clicking on them change the color value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
