[mapguide][MG222][New] GETSPATIALCONTEXTS request accepts empty ACTIVEONLY paramete...
Alain Lebatard alain.lebatard at autodesk.com
Fri Apr 14 13:46:46 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG222
Type
 Defect
Artifact ID
 MG222 (GETSPATIALCONTEXTS request accepts empty ACTIVEONLY parameter)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Artifact Status set to new value
  New
- Artifact created
- Subcomponent set to new value
  Feature Service
- Defect Severity set to new value
  Low
- Steps to Reproduce set to new value
  Using the test forms make a GETSPATIALCONTEXTS request leaving empty the field "Active only"
-> request go through. It should return an exception Invalid parameter
- Version set to new value
  1.0.0
- Platform set to new value
  All
- Component set to new value
  Web Server Extensions
- Description set to new value
  The request GETSPATIALCONTEXTS accepts an empty ACTIVEONLY parameter. This parameter is mandatory and should only allow values '0' or '1'
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
