[mapguide][MG227][Modified] Server/Web Tier Configuration Validation
Steve Dang steve.dang at autodesk.com
Mon Apr 17 03:58:57 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG227
Type:
Defect
Artifact ID:
MG227 (Server/Web Tier Configuration Validation)
Modified by:
Steve Dang
stevedang (steve.dang at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
Modified
File: trunk/MgDev/Common/Service/Services/SiteConnection.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Services/SiteConnection.cpp?view=diff&rev=515&p1=trunk/MgDev/Common/Service/Services/SiteConnection.cpp&r1=514&p2=trunk/MgDev/Common/Service/Services/SiteConnection.cpp&r2=515
File: trunk/MgDev/Common/Service/System/ConfigProperties.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/System/ConfigProperties.cpp?view=diff&rev=515&p1=trunk/MgDev/Common/Service/System/ConfigProperties.cpp&r1=514&p2=trunk/MgDev/Common/Service/System/ConfigProperties.cpp&r2=515
File: trunk/MgDev/Common/Service/System/ConfigProperties.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/System/ConfigProperties.h?view=diff&rev=515&p1=trunk/MgDev/Common/Service/System/ConfigProperties.h&r1=514&p2=trunk/MgDev/Common/Service/System/ConfigProperties.h&r2=515
File: trunk/MgDev/Common/Service/System/Configuration.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/System/Configuration.cpp?view=diff&rev=515&p1=trunk/MgDev/Common/Service/System/Configuration.cpp&r1=514&p2=trunk/MgDev/Common/Service/System/Configuration.cpp&r2=515
File: trunk/MgDev/Common/Service/System/Configuration.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/System/Configuration.h?view=diff&rev=515&p1=trunk/MgDev/Common/Service/System/Configuration.h&r1=514&p2=trunk/MgDev/Common/Service/System/Configuration.h&r2=515
File: trunk/MgDev/Common/Service/System/ConfigurationHeap.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/System/ConfigurationHeap.cpp?view=diff&rev=515&p1=trunk/MgDev/Common/Service/System/ConfigurationHeap.cpp&r1=514&p2=trunk/MgDev/Common/Service/System/ConfigurationHeap.cpp&r2=515
File: trunk/MgDev/Common/Service/System/ConfigurationHeap.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/System/ConfigurationHeap.h?view=diff&rev=515&p1=trunk/MgDev/Common/Service/System/ConfigurationHeap.h&r1=514&p2=trunk/MgDev/Common/Service/System/ConfigurationHeap.h&r2=515
File: trunk/MgDev/Server/src/Core/ResourceChangeEventHandler.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Core/ResourceChangeEventHandler.cpp?view=diff&rev=515&p1=trunk/MgDev/Server/src/Core/ResourceChangeEventHandler.cpp&r1=514&p2=trunk/MgDev/Server/src/Core/ResourceChangeEventHandler.cpp&r2=515
File: trunk/MgDev/Server/src/Core/SessionTimeoutEventHandler.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Core/SessionTimeoutEventHandler.cpp?view=diff&rev=515&p1=trunk/MgDev/Server/src/Core/SessionTimeoutEventHandler.cpp&r1=514&p2=trunk/MgDev/Server/src/Core/SessionTimeoutEventHandler.cpp&r2=515
File: trunk/MgDev/Server/src/Core/serverconfig.ini https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Core/serverconfig.ini?view=diff&rev=515&p1=trunk/MgDev/Server/src/Core/serverconfig.ini&r1=514&p2=trunk/MgDev/Server/src/Core/serverconfig.ini&r2=515
File: trunk/MgDev/Server/src/Resources/server_en.res https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Resources/server_en.res?view=diff&rev=515&p1=trunk/MgDev/Server/src/Resources/server_en.res&r1=514&p2=trunk/MgDev/Server/src/Resources/server_en.res&r2=515
File: trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.cpp?view=diff&rev=515&p1=trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.cpp&r1=514&p2=trunk/MgDev/Server/src/UnitTesting/TestServerAdminService.cpp&r2=515
File: trunk/MgDev/Web/src/mapagent/Resources/web_en.res https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/mapagent/Resources/web_en.res?view=diff&rev=515&p1=trunk/MgDev/Web/src/mapagent/Resources/web_en.res&r1=514&p2=trunk/MgDev/Web/src/mapagent/Resources/web_en.res&r2=515
File: trunk/MgDev/Web/src/webconfig.ini https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Web/src/webconfig.ini?view=diff&rev=515&p1=trunk/MgDev/Web/src/webconfig.ini&r1=514&p2=trunk/MgDev/Web/src/webconfig.ini&r2=515
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
