[mapguide][MG229][New] Crash when retrieving exception msg if MgInitializeWebTier w...
Alain Lebatard
alain.lebatard at autodesk.com
Mon Apr 17 19:19:16 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG229
Type
Defect
Artifact ID
MG229 (Crash when retrieving exception msg if MgInitializeWebTier was not called)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Defect Severity set to new value
Critical
- Component set to new value
Web Server Extensions
- Subcomponent set to new value
Web API
- Platform set to new value
All
- Description set to new value
When an exception occurs in a MapGuide API and the calling script tries to retrieve the exception message, the application crashes if the script did not call MgInitializeWebTier().
- Version set to new value
1.0.0
- Steps to Reproduce set to new value
The following PHP script crashes the php-cgfi.exe:
<?php
try
$rw = new MgWktReaderWriter();
$geom = $rw->Read("POLYGON ((10 10, 10 -10, -10 -10, -10 10, 10 10)");
} catch(MgException $e) {
echo $e->GetDetails();
- Artifact Status set to new value
New
- Artifact created
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
