[mapguide][MG232][New] Update FDO connection cache
Bruce Dechant bruce.dechant at autodesk.com
Mon Apr 17 20:24:08 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG232
Type
 Enhancement
Artifact ID
 MG232 (Update FDO connection cache)
Reported by
 Bruce Dechant
 brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Justification set to new value
  Increased performance and usability.
- Artifact Status set to new value
  New
- Priority set to new value
  P2
- Artifact created
- Summary set to new value
- Target milestone set to new value
  1.0.1
- Description set to new value
  Update the code with the following changes:
1) Better synchronization of entries in the cache
2) Returns an uncached FDO connection if the cache is full and all entries in the cache are in use, otherwise removes an unused entry in the cache and caches the new FDO connection
3) Properly removes entries from the cache if a resource is being deleted and it is not in use. If the resouce to be deleted is in use a ResourceBusyException is returned.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
