[mapguide][MG234][Modified] Fix MgStringCollection class
    Walt Welton-Lair
    walt.welton-lair at autodesk.com
    Tue Apr 18 13:53:53 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG234
Type:
Defect
Artifact ID:
MG234 (Fix MgStringCollection class)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Testing Notes set to new value:
Ran server unit tests: 380 passed
Ran web tier unit tests:
- some of these are
-- Developer Notes set to new value:
Updated the class to simply store a vector of strings.
Also cleaned up other classes in Services/Data.
There were bugs in IntCollection::ValidateIndex.  It wouldn't check for a negative index, and it also accepted the case of an index equal to the size of the array.
Fixed a bug in the GetSpatialContext HTTP web tier unit test.  The test was not including the required ACTIVEONLY parameter as part of the request.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
