[mapguide][MG235][New] Fix server unittests illegal path in serverconfig.ini
Tim Strang
tim.strang at autodesk.com
Tue Apr 18 15:27:54 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG235
Type
Enhancement
Artifact ID
MG235 (Fix server unittests illegal path in serverconfig.ini)
Reported by
Tim Strang
timstrang (tim.strang at autodesk.com)
New artifact details:
- Description set to new value
Fix the sever UnitTests failing by updating an illegal path in serverconfig.ini.
Recent changes to the server to check for illegal paths caused this problem to surface.
- Artifact created
- Summary set to new value
- Build set to new value
171.1
- Priority set to new value
P1
- Artifact Status set to new value
New
- Justification set to new value
UnitTests are broken.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
