[mapguide][MG237][New] Selection from search result list doesn't work with DWF view...
Alain Lebatard
alain.lebatard at autodesk.com
Tue Apr 18 18:42:57 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG237
Type
Defect
Artifact ID
MG237 (Selection from search result list doesn't work with DWF viewer)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Description set to new value
Selectiing a feature in the result list after a search does not work when the feature is not in the current view extent.
- Version set to new value
1.0.0
- Summary set to new value
- Defect Severity set to new value
High
- Component set to new value
Web Server Extensions
- Platform set to new value
All
- Artifact Status set to new value
New
- Artifact created
- Subcomponent set to new value
Viewer Command
- Steps to Reproduce set to new value
Open a web layout with a search command
Execute the search so it brings results
Make sure one of the features in the result list is not visible in the current map view
Click on this feature in the result list
-> nothing happens. The feature should be selected, and the map should zoom to the selection
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
