[mapguide][MG241][New] Use default locale as a backup when loading resource strings
Walt Welton-Lair
walt.welton-lair at autodesk.com
Wed Apr 19 14:37:01 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG241
Type
Defect
Artifact ID
MG241 (Use default locale as a backup when loading resource strings)
Reported by
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
New artifact details:
- Artifact created
- Summary set to new value
- Priority set to new value
P3
- Steps to Reproduce set to new value
1/ On an English installation of the server enter the following request:
http://localhost/mapguide/mapviewerajax/?LOCALE=ja&WEBLAYOUT=Library%3a%2f%2fSamples%2fSheboygan%2fLayouts%2fSheboyganPhp.WebLayout
2/ In the authentication dialog enter garbage credentials.
The server responds with:
Failed to retrieve message for "MgAuthenticationFailedException".
- Platform set to new value
All
- Artifact Status set to new value
New
- Subcomponent set to new value
Core
- Target milestone set to new value
1.0.1
- Component set to new value
All
- Operating system set to new value
All
- Description set to new value
When an exception is thrown we look up a message from the locale-specific resource file. If the file is missing then the message ends up being "Failed to retrieve message for xxx".
In the case where the locale is not the default, we can make an additional attempt to use the resource file associated with the defaule locale. If that file is found then the message will come back in the wrong language, but at least that's better then ""Failed to retrieve message for xxx".
- Defect Severity set to new value
High
- Version set to new value
1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
