[mapguide][MG241][Modified] Use default locale as a backup when loading resource strings
Walt Welton-Lair walt.welton-lair at autodesk.com
Wed Apr 19 15:10:11 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG241
Type:
Defect
Artifact ID:
MG241 (Use default locale as a backup when loading resource strings)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Resolution set to new value:
Submitted
-- Developer Notes set to new value:
Simply added one more check in Exception.cpp.  If the resource string is not found when using the supplied locale, try looking it up again using the default locale.
BTW, this fix works for both the server and web-tier.
-- Resolution Description set to new value:
Code fix has been submitted.
-- Status Explanation set to new value:
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
