[mapguide][MG243][Modified] Font matching wrong for Type 1 and TrueTypeCollection fonts ...
Traian Stanev traian.stanev at autodesk.com
Wed Apr 19 15:39:07 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG243
Type:
Defect
Artifact ID:
MG243 (Font matching wrong for Type 1 and TrueTypeCollection fonts on Windows)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- Status Explanation set to new value:
Fixed.
-- Resolution set to new value:
Submitted
-- Resolution Description set to new value:
Removed code that was forcing only .ttf files to be considered as fonts. Now all files in the directory are read and only if FreeType returns an error for the file we skip adding it to the font list. Note that the Linux version of the code was already doing that.
-- Artifact Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
