[mapguide][MG243][Modified] Font matching wrong for Type 1 and TrueTypeCollection fonts ...
    Walt Welton-Lair
    walt.welton-lair at autodesk.com
    Wed Apr 19 16:04:26 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG243
Type:
Defect
Artifact ID:
MG243 (Font matching wrong for Type 1 and TrueTypeCollection fonts on Windows)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Submission Reviewed set to new value:
Yes
-- Resolution Description set to new value:
Old value:
Removed code that was forcing only .ttf files to be considered as fonts. Now all files in the directory are read and only if FreeType returns an error for the file we skip adding it to the font list. Note that the Linux version of the code was already doing that.
New value:
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
