[mapguide][MG244][New] GLOB: Truncated right click menu within layer pane.
Alain Lebatard alain.lebatard at autodesk.com
Wed Apr 19 17:11:00 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG244
Type
 Defect
Artifact ID
 MG244 (GLOB: Truncated right click menu within layer pane.)
Reported by
 Alain Lebatard
 alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Artifact Status set to new value
  New
- Subcomponent set to new value
  General
- Artifact created
- Defect Severity set to new value
  High
- Steps to Reproduce set to new value
  1. LOCALE=ja
2. Open SheboyganPhp sample file from IE AJAX Viewer.
3. Right click on either 'Base Map' or 'Municipal' folder.
Problem: menu items are truncated.
- Component set to new value
  Web Server Extensions
- Description set to new value
  The legend control contextual menu associated with groups is truncated in Japanese web layout
- Summary set to new value
- Version set to new value
  1.0.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
