[mapguide][MG245][Modified] Print layout elements overlap when Title not selected
Ronnie Louie
ronnie.louie at autodesk.com
Thu Apr 20 01:04:35 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG245
Type:
Defect
Artifact ID:
MG245 (Print layout elements overlap when Title not selected)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
-- Build set to new value:
171.3
-- Testing Notes set to new value:
Server unit tests debug: 379/379 tests OK
Server unit tests release: 379/379 tests OK
-- External ID set to new value:
771145
-- Resolution Description set to new value:
Print layout elements not positioned properly due to incorrect map height. Map height needed to be adjusted such that print layout elements have enough space to display correctly.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
