[mapguide][MG246][Modified] Fix crash in GDRenderer::DrawString
Walt Welton-Lair walt.welton-lair at autodesk.com
Thu Apr 20 13:31:40 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG246
Type:
Defect
Artifact ID:
MG246 (Fix crash in GDRenderer::DrawString)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Developer Notes set to new value:
While working on this I also noticed that in Linux the WT_String::to_wchar() method did not properly NULL terminate the returned string.  This is a bug in Whip toolkit, and I've fixed it in our copy of the toolkit.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
