[mapguide][MG247][New] Digitizing leaves unwanted HTML element at the bottom of the...
Alain Lebatard
alain.lebatard at autodesk.com
Fri Apr 21 12:52:29 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG247
Type
Defect
Artifact ID
MG247 (Digitizing leaves unwanted HTML element at the bottom of the viewer page)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Steps to Reproduce set to new value
From a client-side script call any digitizing function, say DigitizePoint
-> The map shift slight upward and a small gray area appears at the bottom of it.
- Artifact created
- Description set to new value
Starting any digitizing function in the AJAX viewer creates a small gray area about 10 pixels high with some truncated text in it at the bottom of the map (see attachement)
This happens only with Firefox.
- Summary set to new value
- Artifact Status set to new value
New
- Component set to new value
Web Server Extensions
- Subcomponent set to new value
AJAX Viewer
- Version set to new value
1.0.0
- Added file attachment
- Defect Severity set to new value
Medium
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
