[mapguide][MG248][New] Weirdness in AJAX rectangle selection feedback behavior
Alain Lebatard
alain.lebatard at autodesk.com
Fri Apr 21 13:55:40 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG248
Type
Defect
Artifact ID
MG248 (Weirdness in AJAX rectangle selection feedback behavior)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Artifact created
- Subcomponent set to new value
AJAX Viewer
- Steps to Reproduce set to new value
In the AJAX viewer in IE, set the current tool to 'Select'
Click and start extending the selection to the right without moving down:
=> The rectangle should be 1 pixel high at that point, but it's about 20 pixels high.
Move the mouse slowly upward:
=> The whole rectangle moves up instead of staying anchored to the original point of click.
- Defect Severity set to new value
Medium
- Summary set to new value
- Component set to new value
Web Server Extensions
- Version set to new value
1.0.0
- Description set to new value
There is some odd behavior with small rectangle selection in the AJAX viewer with IE. Behavior in Firefox is fine.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
