[mapguide][MG250][Modified] WebExtentions unit tests are failing. WFS GetFeature is test...
Konstantin Nikolov
konstantin.nikolov at autodesk.com
Fri Apr 21 18:31:45 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG250
Type:
Defect
Artifact ID:
MG250 (WebExtentions unit tests are failing. WFS GetFeature is tested only with HTTP GET requests.)
Modified by:
Konstantin Nikolov
konstantinnikolov (konstantin.nikolov at autodesk.com)
The following modifications were made to this artifact:
-- Resolution set to new value:
Submitted
-- Status Explanation set to new value:
Submitted code fix
-- Artifact Status changed:
Old value:
New
New value:
Resolved
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
