[mapguide][MG252][Modified] Server hung/crashed after running load tests
Steve Dang
steve.dang at autodesk.com
Sun Apr 23 02:13:07 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG252
Type:
Defect
Artifact ID:
MG252 (Server hung/crashed after running load tests)
Modified by:
Steve Dang
stevedang (steve.dang at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
MG252 (Partial fix - Server hung/crashed after running load tests)
Modified
File: trunk/MgDev/Common/Service/Net/IOperationHandler.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Net/IOperationHandler.h?view=diff&rev=555&p1=trunk/MgDev/Common/Service/Net/IOperationHandler.h&r1=554&p2=trunk/MgDev/Common/Service/Net/IOperationHandler.h&r2=555
File: trunk/MgDev/Common/Service/Services/Command.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Service/Services/Command.h?view=diff&rev=555&p1=trunk/MgDev/Common/Service/Services/Command.h&r1=554&p2=trunk/MgDev/Common/Service/Services/Command.h&r2=555
File: trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp&r1=554&p2=trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp&r2=555
File: trunk/MgDev/Server/src/Common/Base/ServiceOperation.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Common/Base/ServiceOperation.h?view=diff&rev=555&p1=trunk/MgDev/Server/src/Common/Base/ServiceOperation.h&r1=554&p2=trunk/MgDev/Server/src/Common/Base/ServiceOperation.h&r2=555
File: trunk/MgDev/Server/src/Core/EventTimer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Core/EventTimer.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Core/EventTimer.cpp&r1=554&p2=trunk/MgDev/Server/src/Core/EventTimer.cpp&r2=555
File: trunk/MgDev/Server/src/Core/OperationThread.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Core/OperationThread.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Core/OperationThread.cpp&r1=554&p2=trunk/MgDev/Server/src/Core/OperationThread.cpp&r2=555
File: trunk/MgDev/Server/src/Core/Server.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Core/Server.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Core/Server.cpp&r1=554&p2=trunk/MgDev/Server/src/Core/Server.cpp&r2=555
File: trunk/MgDev/Server/src/Core/ServiceHandlerFactory.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Core/ServiceHandlerFactory.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Core/ServiceHandlerFactory.cpp&r1=554&p2=trunk/MgDev/Server/src/Core/ServiceHandlerFactory.cpp&r2=555
File: trunk/MgDev/Server/src/Core/main.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Core/main.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Core/main.cpp&r1=554&p2=trunk/MgDev/Server/src/Core/main.cpp&r2=555
File: trunk/MgDev/Server/src/Core/serverconfig.ini https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Core/serverconfig.ini?view=diff&rev=555&p1=trunk/MgDev/Server/src/Core/serverconfig.ini&r1=554&p2=trunk/MgDev/Server/src/Core/serverconfig.ini&r2=555
File: trunk/MgDev/Server/src/Services/Drawing/DrawingServiceHandler.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Drawing/DrawingServiceHandler.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Drawing/DrawingServiceHandler.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Drawing/DrawingServiceHandler.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Drawing/OpDescribeDrawing.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Drawing/OpDescribeDrawing.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Drawing/OpDescribeDrawing.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Drawing/OpDescribeDrawing.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Drawing/OpEnumerateLayers.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Drawing/OpEnumerateLayers.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Drawing/OpEnumerateLayers.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Drawing/OpEnumerateLayers.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Drawing/OpEnumerateSectionResources.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Drawing/OpEnumerateSectionResources.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Drawing/OpEnumerateSectionResources.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Drawing/OpEnumerateSectionResources.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Drawing/OpEnumerateSections.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Drawing/OpEnumerateSections.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Drawing/OpEnumerateSections.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Drawing/OpEnumerateSections.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Drawing/OpGetCoordinateSpace.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Drawing/OpGetCoordinateSpace.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Drawing/OpGetCoordinateSpace.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Drawing/OpGetCoordinateSpace.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Drawing/OpGetDrawing.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Drawing/OpGetDrawing.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Drawing/OpGetDrawing.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Drawing/OpGetDrawing.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Drawing/OpGetLayer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Drawing/OpGetLayer.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Drawing/OpGetLayer.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Drawing/OpGetLayer.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Drawing/OpGetSection.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Drawing/OpGetSection.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Drawing/OpGetSection.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Drawing/OpGetSection.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Drawing/OpGetSectionResource.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Drawing/OpGetSectionResource.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Drawing/OpGetSectionResource.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Drawing/OpGetSectionResource.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/FeatureServiceHandler.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/FeatureServiceHandler.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/FeatureServiceHandler.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/FeatureServiceHandler.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpCloseDataReader.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpCloseDataReader.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpCloseDataReader.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpCloseDataReader.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpCloseFeatureReader.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpCloseFeatureReader.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpCloseFeatureReader.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpCloseFeatureReader.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpCloseGwsFeatureReader.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpCloseGwsFeatureReader.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpCloseGwsFeatureReader.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpCloseGwsFeatureReader.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpCloseSqlReader.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpCloseSqlReader.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpCloseSqlReader.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpCloseSqlReader.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpCreateFeatureSource.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpCreateFeatureSource.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpCreateFeatureSource.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpCreateFeatureSource.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpDescribeSchema.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpDescribeSchema.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpDescribeSchema.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpDescribeSchema.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpDescribeSchemaAsXml.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpDescribeSchemaAsXml.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpDescribeSchemaAsXml.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpDescribeSchemaAsXml.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpDescribeWfsFeatureType.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpDescribeWfsFeatureType.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpDescribeWfsFeatureType.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpDescribeWfsFeatureType.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpEnumerateDataStores.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpEnumerateDataStores.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpEnumerateDataStores.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpEnumerateDataStores.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlNonQuery.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlNonQuery.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlNonQuery.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlNonQuery.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlQuery.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlQuery.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlQuery.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpExecuteSqlQuery.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpGetCapabilities.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpGetCapabilities.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpGetCapabilities.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpGetCapabilities.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpGetClassDefinition.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpGetClassDefinition.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpGetClassDefinition.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpGetClassDefinition.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpGetClasses.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpGetClasses.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpGetClasses.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpGetClasses.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpGetConnectionPropertyValues.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpGetConnectionPropertyValues.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpGetConnectionPropertyValues.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpGetConnectionPropertyValues.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpGetDataRows.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpGetDataRows.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpGetDataRows.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpGetDataRows.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpGetFeatureProviders.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpGetFeatureProviders.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpGetFeatureProviders.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpGetFeatureProviders.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpGetFeatures.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpGetFeatures.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpGetFeatures.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpGetFeatures.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpGetIdentityProperties.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpGetIdentityProperties.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpGetIdentityProperties.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpGetIdentityProperties.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpGetLongTransactions.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpGetLongTransactions.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpGetLongTransactions.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpGetLongTransactions.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpGetRaster.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpGetRaster.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpGetRaster.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpGetRaster.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpGetSchemaMapping.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpGetSchemaMapping.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpGetSchemaMapping.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpGetSchemaMapping.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpGetSchemas.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpGetSchemas.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpGetSchemas.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpGetSchemas.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpGetSpatialContexts.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpGetSpatialContexts.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpGetSpatialContexts.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpGetSpatialContexts.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpGetSqlRows.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpGetSqlRows.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpGetSqlRows.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpGetSqlRows.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpGetWfsFeature.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpGetWfsFeature.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpGetWfsFeature.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpGetWfsFeature.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpSchemaToXml.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpSchemaToXml.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpSchemaToXml.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpSchemaToXml.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpSelectFeatures.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpSelectFeatures.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpSelectFeatures.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpSelectFeatures.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpSelectFeaturesSpatial.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpSelectFeaturesSpatial.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpSelectFeaturesSpatial.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpSelectFeaturesSpatial.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpTestConnection.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpTestConnection.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpTestConnection.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpTestConnection.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpTestFeatureSourceConnection.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpTestFeatureSourceConnection.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpTestFeatureSourceConnection.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpTestFeatureSourceConnection.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpUpdateFeatures.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpUpdateFeatures.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpUpdateFeatures.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpUpdateFeatures.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Feature/OpXmlToSchema.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Feature/OpXmlToSchema.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Feature/OpXmlToSchema.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Feature/OpXmlToSchema.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Mapping/MappingServiceHandler.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/MappingServiceHandler.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Mapping/MappingServiceHandler.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Mapping/MappingServiceHandler.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Mapping/OpGenerateLegendImage.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/OpGenerateLegendImage.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Mapping/OpGenerateLegendImage.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Mapping/OpGenerateLegendImage.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Mapping/OpGenerateLegendPlot.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/OpGenerateLegendPlot.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Mapping/OpGenerateLegendPlot.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Mapping/OpGenerateLegendPlot.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Mapping/OpGenerateMap.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/OpGenerateMap.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Mapping/OpGenerateMap.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Mapping/OpGenerateMap.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Mapping/OpGenerateMapUpdate.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/OpGenerateMapUpdate.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Mapping/OpGenerateMapUpdate.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Mapping/OpGenerateMapUpdate.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Mapping/OpGenerateMultiPlot.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/OpGenerateMultiPlot.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Mapping/OpGenerateMultiPlot.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Mapping/OpGenerateMultiPlot.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Mapping/OpGeneratePlot.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/OpGeneratePlot.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Mapping/OpGeneratePlot.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Mapping/OpGeneratePlot.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Mapping/OpQueryFeatures.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/OpQueryFeatures.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Mapping/OpQueryFeatures.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Mapping/OpQueryFeatures.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Mapping/OpQueryFeaturesWms.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Mapping/OpQueryFeaturesWms.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Mapping/OpQueryFeaturesWms.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Mapping/OpQueryFeaturesWms.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatureProperties.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatureProperties.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatureProperties.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatureProperties.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatures.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatures.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatures.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Rendering/OpQueryFeatures.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Rendering/OpRenderMapLegend.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Rendering/OpRenderMapLegend.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Rendering/OpRenderMapLegend.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Rendering/OpRenderMapLegend.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Rendering/OpRenderTile.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Rendering/OpRenderTile.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Rendering/OpRenderTile.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Rendering/OpRenderTile.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Rendering/RenderingServiceHandler.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Rendering/RenderingServiceHandler.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Rendering/RenderingServiceHandler.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Rendering/RenderingServiceHandler.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpApplyResourcePackage.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpApplyResourcePackage.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpApplyResourcePackage.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpApplyResourcePackage.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpChangeResourceOwner.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpChangeResourceOwner.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpChangeResourceOwner.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpChangeResourceOwner.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpCopyResource.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpCopyResource.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpCopyResource.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpCopyResource.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpCreateRepository.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpCreateRepository.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpCreateRepository.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpCreateRepository.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpDeleteRepository.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpDeleteRepository.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpDeleteRepository.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpDeleteRepository.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpDeleteResource.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpDeleteResource.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpDeleteResource.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpDeleteResource.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpDeleteResourceData.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpDeleteResourceData.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpDeleteResourceData.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpDeleteResourceData.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpEnumerateParentMapDefinitions.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpEnumerateParentMapDefinitions.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpEnumerateParentMapDefinitions.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpEnumerateParentMapDefinitions.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpEnumerateRepositories.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpEnumerateRepositories.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpEnumerateRepositories.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpEnumerateRepositories.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpEnumerateResourceData.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpEnumerateResourceData.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpEnumerateResourceData.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpEnumerateResourceData.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpEnumerateResourceReferences.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpEnumerateResourceReferences.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpEnumerateResourceReferences.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpEnumerateResourceReferences.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpEnumerateResources.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpEnumerateResources.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpEnumerateResources.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpEnumerateResources.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpGetRepositoryContent.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpGetRepositoryContent.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpGetRepositoryContent.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpGetRepositoryContent.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpGetRepositoryHeader.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpGetRepositoryHeader.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpGetRepositoryHeader.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpGetRepositoryHeader.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpGetResourceContent.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpGetResourceContent.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpGetResourceContent.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpGetResourceContent.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpGetResourceData.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpGetResourceData.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpGetResourceData.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpGetResourceData.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpGetResourceHeader.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpGetResourceHeader.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpGetResourceHeader.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpGetResourceHeader.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpGetResourceModifiedDate.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpGetResourceModifiedDate.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpGetResourceModifiedDate.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpGetResourceModifiedDate.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpInheritPermissionsFrom.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpInheritPermissionsFrom.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpInheritPermissionsFrom.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpInheritPermissionsFrom.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpMoveResource.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpMoveResource.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpMoveResource.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpMoveResource.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpRenameResourceData.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpRenameResourceData.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpRenameResourceData.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpRenameResourceData.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpSetResource.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpSetResource.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpSetResource.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpSetResource.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpSetResourceData.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpSetResourceData.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpSetResourceData.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpSetResourceData.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/OpUpdateRepository.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/OpUpdateRepository.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/OpUpdateRepository.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/OpUpdateRepository.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Resource/ResourceServiceHandler.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Resource/ResourceServiceHandler.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Resource/ResourceServiceHandler.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Resource/ResourceServiceHandler.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpBringOnline.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpBringOnline.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpBringOnline.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpBringOnline.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpClearLog.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpClearLog.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpClearLog.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpClearLog.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpDeleteLog.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpDeleteLog.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpDeleteLog.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpDeleteLog.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpDeletePackage.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpDeletePackage.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpDeletePackage.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpDeletePackage.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpEnableMaximumLogSize.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpEnableMaximumLogSize.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpEnableMaximumLogSize.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpEnableMaximumLogSize.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpEnumerateLogs.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpEnumerateLogs.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpEnumerateLogs.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpEnumerateLogs.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpEnumeratePackages.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpEnumeratePackages.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpEnumeratePackages.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpEnumeratePackages.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpGetConfigurationProperties.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpGetConfigurationProperties.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpGetConfigurationProperties.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpGetConfigurationProperties.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpGetDocument.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpGetDocument.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpGetDocument.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpGetDocument.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpGetInformationProperties.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpGetInformationProperties.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpGetInformationProperties.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpGetInformationProperties.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpGetLog.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpGetLog.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpGetLog.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpGetLog.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpGetLogFile.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpGetLogFile.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpGetLogFile.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpGetLogFile.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpGetPackageLog.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpGetPackageLog.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpGetPackageLog.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpGetPackageLog.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpGetPackageStatus.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpGetPackageStatus.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpGetPackageStatus.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpGetPackageStatus.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpIsMaximumLogSizeEnabled.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpIsMaximumLogSizeEnabled.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpIsMaximumLogSizeEnabled.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpIsMaximumLogSizeEnabled.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpIsOnline.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpIsOnline.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpIsOnline.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpIsOnline.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpLoadPackage.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpLoadPackage.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpLoadPackage.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpLoadPackage.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpMakePackage.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpMakePackage.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpMakePackage.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpMakePackage.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpNotifyResourcesChanged.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpNotifyResourcesChanged.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpNotifyResourcesChanged.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpNotifyResourcesChanged.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpRegisterServicesOnServers.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpRegisterServicesOnServers.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpRegisterServicesOnServers.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpRegisterServicesOnServers.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpRenameLog.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpRenameLog.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpRenameLog.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpRenameLog.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpSetConfigurationProperties.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpSetConfigurationProperties.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpSetConfigurationProperties.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpSetConfigurationProperties.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpSetDocument.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpSetDocument.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpSetDocument.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpSetDocument.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpSetLogDelimiter.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpSetLogDelimiter.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpSetLogDelimiter.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpSetLogDelimiter.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpSetMaximumLogSize.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpSetMaximumLogSize.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpSetMaximumLogSize.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpSetMaximumLogSize.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpTakeOffline.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpTakeOffline.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpTakeOffline.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpTakeOffline.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/OpUnregisterServicesOnServers.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/OpUnregisterServicesOnServers.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/OpUnregisterServicesOnServers.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/OpUnregisterServicesOnServers.cpp&r2=555
File: trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminServiceHandler.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminServiceHandler.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminServiceHandler.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminServiceHandler.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpAddGroup.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpAddGroup.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpAddGroup.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpAddGroup.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpAddServer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpAddServer.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpAddServer.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpAddServer.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpAddUser.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpAddUser.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpAddUser.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpAddUser.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpAuthenticate.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpAuthenticate.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpAuthenticate.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpAuthenticate.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpCreateSession.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpCreateSession.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpCreateSession.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpCreateSession.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpDeleteGroups.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpDeleteGroups.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpDeleteGroups.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpDeleteGroups.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpDeleteUsers.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpDeleteUsers.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpDeleteUsers.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpDeleteUsers.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpDestroySession.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpDestroySession.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpDestroySession.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpDestroySession.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpEnumerateGroups.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpEnumerateGroups.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpEnumerateGroups.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpEnumerateGroups.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpEnumerateRoles.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpEnumerateRoles.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpEnumerateRoles.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpEnumerateRoles.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpEnumerateServers.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpEnumerateServers.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpEnumerateServers.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpEnumerateServers.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpEnumerateUsers.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpEnumerateUsers.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpEnumerateUsers.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpEnumerateUsers.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpGrantGroupMembershipsToUsers.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpGrantGroupMembershipsToUsers.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpGrantGroupMembershipsToUsers.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpGrantGroupMembershipsToUsers.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpGrantRoleMembershipsToGroups.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpGrantRoleMembershipsToGroups.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpGrantRoleMembershipsToGroups.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpGrantRoleMembershipsToGroups.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpGrantRoleMembershipsToUsers.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpGrantRoleMembershipsToUsers.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpGrantRoleMembershipsToUsers.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpGrantRoleMembershipsToUsers.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpRemoveServer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpRemoveServer.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpRemoveServer.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpRemoveServer.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpRequestServer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpRequestServer.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpRequestServer.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpRequestServer.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpRevokeGroupMembershipsFromUsers.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpRevokeGroupMembershipsFromUsers.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpRevokeGroupMembershipsFromUsers.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpRevokeGroupMembershipsFromUsers.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpRevokeRoleMembershipsFromGroups.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpRevokeRoleMembershipsFromGroups.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpRevokeRoleMembershipsFromGroups.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpRevokeRoleMembershipsFromGroups.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpRevokeRoleMembershipsFromUsers.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpRevokeRoleMembershipsFromUsers.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpRevokeRoleMembershipsFromUsers.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpRevokeRoleMembershipsFromUsers.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpUpdateGroup.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpUpdateGroup.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpUpdateGroup.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpUpdateGroup.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpUpdateServer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpUpdateServer.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpUpdateServer.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpUpdateServer.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/OpUpdateUser.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/OpUpdateUser.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/OpUpdateUser.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/OpUpdateUser.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Site/SiteServiceHandler.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Site/SiteServiceHandler.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Site/SiteServiceHandler.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Site/SiteServiceHandler.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Tile/OpClearCache.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Tile/OpClearCache.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Tile/OpClearCache.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Tile/OpClearCache.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Tile/OpGetTile.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Tile/OpGetTile.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Tile/OpGetTile.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Tile/OpGetTile.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Tile/OpSetTile.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Tile/OpSetTile.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Tile/OpSetTile.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Tile/OpSetTile.cpp&r2=555
File: trunk/MgDev/Server/src/Services/Tile/TileServiceHandler.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Server/src/Services/Tile/TileServiceHandler.cpp?view=diff&rev=555&p1=trunk/MgDev/Server/src/Services/Tile/TileServiceHandler.cpp&r1=554&p2=trunk/MgDev/Server/src/Services/Tile/TileServiceHandler.cpp&r2=555
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
