[mapguide][MG254][Modified] Buffer and measure command fail with unclassified exception
Alain Lebatard
alain.lebatard at autodesk.com
Tue Apr 25 17:52:46 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG254
Type:
Defect
Artifact ID:
MG254 (Buffer and measure command fail with unclassified exception)
Modified by:
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
The following modifications were made to this artifact:
-- Target milestone set to new value:
1.0.0
-- Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution Description set to new value:
An smart pointer was missing an addref leading to double destruction of the pointed object. (applied the same fix in two other places)
A delete was invoked on a smart pointer. Please don't do that...
-- Build set to new value:
172.3
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
