[mapguide][MG256][New] Rewrite point stylization to make it faster
Traian Stanev traian.stanev at autodesk.com
Wed Apr 26 10:09:00 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG256
Type
 Defect
Artifact ID
 MG256 (Rewrite point stylization to make it faster)
Reported by
 Traian Stanev
 traianstanev (traian.stanev at autodesk.com)
New artifact details:
- Defect Severity set to new value
  Medium
- Steps to Reproduce set to new value
  Add a point layer with thousands of points and preview in the AJAX viewer. Set a symbol from the library and it's even worse.
- Platform set to new value
  All
- Component set to new value
  Server
- Priority set to new value
  P2
- Version set to new value
  1.0.0
- Summary set to new value
- Artifact Status set to new value
  New
- Artifact created
- Target milestone set to new value
  1.0.1
- Description set to new value
  Layers with many points would perform slowly in some cases. This was because the symbol was read from the library every time and this is slow. This was a problem for the AJAX viewer, since the DWF viewer reuses symbol data via the Macro opcode.
- Operating system set to new value
  All
- Subcomponent set to new value
  Rendering Service
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
