[mapguide][MG259][New] MgFeatureService->CreateFeatureSource doesn't require identi...
Alain Lebatard
alain.lebatard at autodesk.com
Wed Apr 26 16:22:58 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG259
Type
Defect
Artifact ID
MG259 (MgFeatureService->CreateFeatureSource doesn't require identity property for SDF)
Reported by
Alain Lebatard
alainlebatard (alain.lebatard at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Artifact created
- Description set to new value
MgFeatureService->CreateFeatureSource allows a programmer to create an SDF without an Identity property which is apparently mandatory. An exception should be raised and the SDF should not be created.
- Summary set to new value
- Component set to new value
Server
- Version set to new value
1.0.0
- Defect Severity set to new value
High
- Steps to Reproduce set to new value
- Subcomponent set to new value
Feature Service
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
