[mapguide][MG256][Modified] Rewrite point stylization to make it faster
Traian Stanev traian.stanev at autodesk.com
Fri Apr 28 09:15:03 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG256
Type:
Defect
Artifact ID:
MG256 (Rewrite point stylization to make it faster)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
Defect ID MG256: Rewrite point stylization to make it faster
This is a fix for the new symbol code concerning DWF symbols which contain lines with 0 width. In that case we need to take into account the supersampling factor (if any) into the line width, otherwise it looks faded due to the scaling down of the cached symbol image. Crazy.
Modified
File: trunk/MgDev/Common/Stylization/GDRenderer.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/GDRenderer.cpp?view=diff&rev=587&p1=trunk/MgDev/Common/Stylization/GDRenderer.cpp&r1=586&p2=trunk/MgDev/Common/Stylization/GDRenderer.cpp&r2=587
File: trunk/MgDev/Common/Stylization/GDRenderer.h https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/GDRenderer.h?view=diff&rev=587&p1=trunk/MgDev/Common/Stylization/GDRenderer.h&r1=586&p2=trunk/MgDev/Common/Stylization/GDRenderer.h&r2=587
File: trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp?view=diff&rev=587&p1=trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp&r1=586&p2=trunk/MgDev/Common/Stylization/GDW2DRewriter.cpp&r2=587
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
