[mapguide][MG264][New] ResourceDataFileTrashFolderName set incorrectly in Linux ser...
Hartesh Chhabra
hartesh.chhabra at autodesk.com
Fri Apr 28 14:52:44 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG264
Type
Defect
Artifact ID
MG264 (ResourceDataFileTrashFolderName set incorrectly in Linux serverconfig.ini)
Reported by
Hartesh Chhabra
harteshchhabra (hartesh.chhabra at autodesk.com)
New artifact details:
- Target milestone set to new value
1.0.1
- Steps to Reproduce set to new value
Start Site Administrator
Click on Configure Services link
- Defect Severity set to new value
Medium
- Subcomponent set to new value
Map Admin
- Priority set to new value
P1
- Operating system set to new value
Linux
- Description set to new value
This leads to error while opening Configure Services page in Site Administrator:
"Configuration exception: serverconfig.ini The value of property ResourceDataFileTrashFolderName under section ResourceServiceProperties is /opt/Autodesk/mapguideenterprise2007/server/Trash/. It must not contain any of the following reserved characters: \/:*?"<>|". Most remaining property fileds are blank.
- Platform set to new value
otherOS
- Artifact Status set to new value
New
- Version set to new value
1.0.0
- Summary set to new value
- Component set to new value
Web Server Extensions
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
