[mapguide][MG265][New] Remove field corresponding to DataConnectionPoolEnabled from...
Hartesh Chhabra
hartesh.chhabra at autodesk.com
Fri Apr 28 15:03:31 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG265
Type
Defect
Artifact ID
MG265 (Remove field corresponding to DataConnectionPoolEnabled from Site Administrator)
Reported by
Hartesh Chhabra
harteshchhabra (hartesh.chhabra at autodesk.com)
New artifact details:
- Operating system set to new value
All
- Version set to new value
1.0.0
- Summary set to new value
- Component set to new value
Web Server Extensions
- Platform set to new value
All
- Artifact Status set to new value
New
- Target milestone set to new value
1.0.1
- Subcomponent set to new value
Map Admin
- Steps to Reproduce set to new value
Start Site Administrator
Click on configure Services link
Feature Services section has field for DataConnectionPoolEnabled which need to be removed.
- Description set to new value
DataConnectionPoolEnabled parameter has been removed from serverconfig.ini file. This needs to be removed from Site Administrator as well.
- Defect Severity set to new value
Medium
- Priority set to new value
P2
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
