[mapguide][MG266][Modified] Label offset for point symbols does not take into account ro...
Traian Stanev
traian.stanev at autodesk.com
Fri Apr 28 17:10:25 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG266
Type:
Defect
Artifact ID:
MG266 (Label offset for point symbols does not take into account rotation)
Modified by:
Traian Stanev
traianstanev (traian.stanev at autodesk.com)
The following modifications were made to this artifact:
-- Submission Reviewed set to new value:
No
-- Resolution Description set to new value:
There are a couple of things that could be done to fix this. One is to increase the offset of the label from the symbol center point by an amount corresponding to the increase of the symbol extents due to rotation. The second is to avoid overpost checks for a label against its own symbol. I have implemented the first, which guarantees that the second won't be necessary. The downside of it is that the label can be somewhat far away from the symbol if the symbol data does not take up the full bounding rectangle.
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
