[mapguide][MG267][New] Update description for port number used for Admin/client/sit...
Hartesh Chhabra
hartesh.chhabra at autodesk.com
Sat Apr 29 15:21:20 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG267
Type
Defect
Artifact ID
MG267 (Update description for port number used for Admin/client/site operations in serverconfig.ini and webconfig.ini files)
Reported by
Hartesh Chhabra
harteshchhabra (hartesh.chhabra at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Target milestone set to new value
1.0.1
- Defect Severity set to new value
Medium
- Summary set to new value
- Version set to new value
1.0.0
- Steps to Reproduce set to new value
Change port number for let's say Administrative operations in serverconfig.ini file.
Administrative operations wouldn't be processed until port number for Administrative operations is updated in webconfig.ini file to match the one in serverconfig.ini file
- Artifact created
- Description set to new value
If port number used for Administrative or Cleint or Site opertaions is updated in serverconfig.ini file, the corresponding port number need to be updated in webconfig.ini file as well and vice versa
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
