[mapguide][MG347][New] Admin - page 2 of Load Packages Broken Link
Andrew Morsell
amorsell at spatialgis.com
Tue Aug 1 20:00:06 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG347
Type
Defect
Artifact ID
MG347 (Admin - page 2 of Load Packages Broken Link)
Reported by
Andrew Morsell
amorsell (amorsell at spatialgis.com)
New artifact details:
- Summary set to new value
- Component set to new value
Web Server Extensions
- Subcomponent set to new value
Map Admin
- Operating system set to new value
All
- Version set to new value
1.0.1
- Platform set to new value
All
- Artifact Status set to new value
New
- Artifact created
- Defect Severity set to new value
Medium
- Steps to Reproduce set to new value
Following the above steps should yeild the same results. I confirmed the problem in both Internet Explorer and Firefox.
- Description set to new value
I apparently have enough packages in my packages folder to necesitate the Admin Manage Packages page to be split into page 1 and 2. However, when I click on the number 2 or Next, I get a page not found error at the following: http://localhost/mapguide/MapAdmin/loadpackages.php?TablePageID=2
It looks like the proper link should be: http://localhost/mapguide/MapAdmin/packagemanagement.php?TablePageID=2
The same applies to the Prev button.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
