[mapguide][MG352][New] SelectAggregates in server is inefficient
Ronnie Louie
ronnie.louie at autodesk.com
Wed Aug 9 18:09:40 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG352
Type
Defect
Artifact ID
MG352 (SelectAggregates in server is inefficient)
Reported by
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
New artifact details:
- Defect Severity set to new value
High
- External ID set to new value
810162
- Artifact created
- Target milestone set to new value
1.0.2
- Subcomponent set to new value
Feature Service
- Artifact Status set to new value
New
- Priority set to new value
P2
- Description set to new value
The command reads all the records into memory and then scans them to calculate the aggregate property. This will cause a crash if the amount of data is large. And it is more efficient to read and process one record at a time.
- Steps to Reproduce set to new value
Create a php script calling FeatureService::SelectAggregate().
- Version set to new value
1.0.1
- Summary set to new value
- Component set to new value
Server
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
