[mapguide][MG353][New] WMS Calls to MapGuide Open fail with 1.0.1
Andrew Morsell
amorsell at spatialgis.com
Thu Aug 10 01:52:09 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG353
Type
Defect
Artifact ID
MG353 (WMS Calls to MapGuide Open fail with 1.0.1)
Reported by
Andrew Morsell
amorsell (amorsell at spatialgis.com)
New artifact details:
- Version set to new value
1.0.1
- Artifact Status set to new value
New
- Subcomponent set to new value
OGC Interface
- Operating system set to new value
All
- Description set to new value
All WMS calls to MapGuide Open fail with the following:
<ServiceExceptionReport version="1.1.1">
<ServiceException code="InternalError">
The coordinate system conversion failed.
Unsupported coordinate system code.<details>The coordinate system conversion failed.
Exception occurred in method MgCoordinateSystem.ConvertCoordinateSystemCodeToWkt at line 950 in file c:\build_tux_area\mgdev_opensource\common\service\coordinatesystem\CoordinateSystem.cpp
</details>
</ServiceException>
</ServiceExceptionReport>
This occurs even after the fix noted in Artifact 348.
- Steps to Reproduce set to new value
Install MapGuide Open 1.0.1 and call issue a WMS call to a layer exposed to WMS. With the sample Sheboygan dataset installed, try
http://localhost/mapguide/mapagent/mapagent.fcgi?request=GetMap&service=WMS&layers=Samples/Sheboygan/Layers/Hydrography&srs=EPSG:4326&bbox=-87.74,43.68,-87.69,43.815&width=500&height=500&format=image/png
- Platform set to new value
All
- Component set to new value
Server
- Summary set to new value
- Defect Severity set to new value
Critical
- Artifact created
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
