[mapguide][MG350][Modified] Two bugs with expressions for point symbols
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Aug 10 10:03:17 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG350
Type:
Defect
Artifact ID:
MG350 (Two bugs with expressions for point symbols)
Modified by:
Walt Welton-Lair
waltweltonlair (walt.welton-lair at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
The GDRenderer crashes if a symbol widht or height expression evaluates to a negative number. The math assumes width and height are always positive (and they should be).
Another problem is when parsing expressions that represent numbers. An expression like "100 + something" would erroneously be parsed to equal 100, because of the empty space betweem the 100 and the +.
New value:
The GDRenderer crashes if a symbol width or height expression evaluates to a negative number. The math assumes width and height are always positive (and they should be).
-- Submission Reviewed changed:
Old value:
No
New value:
Yes
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
