[mapguide][MG350][Modified] Two bugs with expressions for point symbols
Chris Claydon
chris.claydon at autodesk.com
Fri Aug 11 17:06:14 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG350
Type:
Defect
Artifact ID:
MG350 (Two bugs with expressions for point symbols)
Modified by:
Chris Claydon
chrisclaydon (chris.claydon at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
The GDRenderer crashes if a symbol width or height expression evaluates to a negative number. The math assumes width and height are always positive (and they should be).
Another problem is when parsing expressions that represent numbers. An expression like "100 + something" would erroneously be parsed to equal 100, because of the empty space betweem the 100 and the +.
New value:
Another problem was that point symbols that were cached by the GDRenderer at a given size were not re-created when the requested size changed if the aspect ratio remained the same. This resulted in symbols being rendered at incorrect sizes.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
