[mapguide][MG358][Modified] Additional Platform API work
Trevor Wekel trevor.wekel at autodesk.com
Fri Aug 11 20:34:46 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG358
Type:
Enhancement
Artifact ID:
MG358 (Additional Platform API work)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
MG358: Additional Platform API work
Added
Directory: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetApi
File: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetApi/AssemblyInfo.cs https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/Common/FoundationTest/DotNetApi/AssemblyInfo.cs?view=auto&rev=751
File: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetApi/DotNetApi.vcproj https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/Common/FoundationTest/DotNetApi/DotNetApi.vcproj?view=auto&rev=751
File: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetApi/Localizer.cs https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/Common/FoundationTest/DotNetApi/Localizer.cs?view=auto&rev=751
File: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetApi/Makefile https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/Common/FoundationTest/DotNetApi/Makefile?view=auto&rev=751
File: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetApi/ManagedException.cs https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/Common/FoundationTest/DotNetApi/ManagedException.cs?view=auto&rev=751
Directory: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi
File: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/DotNetUnmanagedApi.rc https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/DotNetUnmanagedApi.rc?view=auto&rev=751
File: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/DotNetUnmanagedApi.vcproj https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/DotNetUnmanagedApi.vcproj?view=auto&rev=751
File: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/catchall.code https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/catchall.code?view=auto&rev=751
Directory: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/custom
File: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/custom/MgColor https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/custom/MgColor?view=auto&rev=751
File: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/custom/MgStringCollection https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/custom/MgStringCollection?view=auto&rev=751
File: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/dotnet.i https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/dotnet.i?view=auto&rev=751
File: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/getclassid.code https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/getclassid.code?view=auto&rev=751
Directory: trunk/MgDev/UnitTest/Common/FoundationTest/MapGuideApi
File: trunk/MgDev/UnitTest/Common/FoundationTest/MapGuideApi/Constants.xml https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/Common/FoundationTest/MapGuideApi/Constants.xml?view=auto&rev=751
File: trunk/MgDev/UnitTest/Common/FoundationTest/MapGuideApi/MapGuideApiGen.xml https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/Common/FoundationTest/MapGuideApi/MapGuideApiGen.xml?view=auto&rev=751
Modified
File: trunk/MgDev/UnitTest/Common/FoundationTest/FoundationTest.cpp https://mapguide.osgeo.org/source/browse/mapguide/trunk/MgDev/UnitTest/Common/FoundationTest/FoundationTest.cpp?view=diff&rev=751&p1=trunk/MgDev/UnitTest/Common/FoundationTest/FoundationTest.cpp&r1=750&p2=trunk/MgDev/UnitTest/Common/FoundationTest/FoundationTest.cpp&r2=751
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
