[mapguide][MG359][New] Long running requests cause Linux Server to exit after MapAg...
Steve Dang
steve.dang at autodesk.com
Mon Aug 14 19:09:52 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG359
Type
Defect
Artifact ID
MG359 (Long running requests cause Linux Server to exit after MapAgent bails)
Reported by
Steve Dang
stevedang (steve.dang at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Priority set to new value
P1
- Description set to new value
Long running requests cause Linux Server to exit after MapAgent bails.
SIGPIPE is a connection failure and should not be considered fatal. According to Linux documentation, handling the SIGPIPE will cause the ::send to return an EPIPE error.
- Target milestone set to new value
1.0.2
- Component set to new value
Server
- Subcomponent set to new value
Core
- Platform set to new value
All
- Defect Severity set to new value
High
- Artifact created
- Operating system set to new value
Linux
- Summary set to new value
- Version set to new value
1.0.1
- Steps to Reproduce set to new value
Create a tiled map so that it takes a long time to render tiles - typically 2 seconds or more.
Bring up the tiled map in the Ajax Viewer and begin panning and zooming. The viewer generates 25+ tile requests. Since the tiles take so long to generate, the MapAgent will be forced to exit by FastCGI. In some cases, the Server will be writing the tile back to the Agent when it kicks out. If this happens, the server receives a SIGPIPE and exits.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
