[mapguide][MG361][New] Correct some out of sync test vectors for the web unit tests...
Steve Dang
steve.dang at autodesk.com
Wed Aug 16 16:59:20 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG361
Type
Task
Artifact ID
MG361 (Correct some out of sync test vectors for the web unit tests.)
Reported by
Steve Dang
stevedang (steve.dang at autodesk.com)
New artifact details:
- Task Priority set to new value
Low
- Artifact created
- Priority set to new value
P4
- Summary set to new value
- Artifact Status set to new value
New
- Description set to new value
Correct some out of sync test vectors for the web unit tests that have been failed since last week. There is no change in code, just updating the web unit test results to correctly reflect the current code.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
