[mapguide][MG362][New] Type in JPEG default output quality
Traian Stanev traian.stanev at autodesk.com
Thu Aug 17 10:02:05 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG362
Type
 Defect
Artifact ID
 MG362 (Type in JPEG default output quality)
Reported by
 Traian Stanev
 traianstanev (traian.stanev at autodesk.com)
New artifact details:
- Target milestone set to new value
  1.0.2
- Steps to Reproduce set to new value
  Request a map as JPEG
- Artifact created
- Version set to new value
  1.0.1
- Summary set to new value
- Artifact Status set to new value
  New
- Priority set to new value
  P3
- Defect Severity set to new value
  Low
- Description set to new value
  The JPEG quality setting is out of 100 and not out of 10 as I originally thought, so 7 is not a good default... Should be 75%.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
