[mapguide][MG364][New] Server throws MgDateTimeException when enumerating versions ...
Bruce Dechant
bruce.dechant at autodesk.com
Thu Aug 17 17:10:54 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG364
Type
Defect
Artifact ID
MG364 (Server throws MgDateTimeException when enumerating versions (long transactions))
Reported by
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Steps to Reproduce set to new value
Create a new Oracle Feature Source in Studio and try and enumerate the Versions and observe the MgDateTimeException.
- Subcomponent set to new value
Feature Service
- Summary set to new value
- Artifact Status set to new value
New
- Artifact created
- Priority set to new value
P2
- Version set to new value
1.0.1
- Platform set to new value
All
- Operating system set to new value
All
- Description set to new value
There is no valid creation date returned from FDO for datastores that are not workspace enabled and the server tries to create a MgDateTime object from the invalid FDO GisDateTime object and fails. The fix is simply to check if the FDO GisDateTime is valid and if not to create a default MgDateTime instead.
- Defect Severity set to new value
Medium
- Component set to new value
Server
- Target milestone set to new value
1.1.0
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
