[mapguide][MG366][New] Fix WebTier Unit Tests
Ronnie Louie ronnie.louie at autodesk.com
Tue Aug 22 12:43:44 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG366
Type
 Defect
Artifact ID
 MG366 (Fix WebTier Unit Tests)
Reported by
 Ronnie Louie
 ronnielouie (ronnie.louie at autodesk.com)
New artifact details:
- Defect Severity set to new value
  Medium
- Priority set to new value
  P3
- Artifact created
- Artifact Status set to new value
  New
- Description set to new value
  The web tier unit tests are broken and need to be updated.
- Version set to new value
  1.0.1
- Component set to new value
  Web Server Extensions
- Steps to Reproduce set to new value
  Run webtier unit test.  All tests should pass successfully.
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues mailing list
