[mapguide][MG367][Modified] Port MapGuide to Platform API codebase
Trevor Wekel
trevor.wekel at autodesk.com
Wed Aug 23 13:19:49 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG367
Type:
Enhancement
Artifact ID:
MG367 (Port MapGuide to Platform API codebase)
Modified by:
Trevor Wekel
trevorwekel (trevor.wekel at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
Update MapGuide Server and Web Extensions code bases to build against the Platform API code base.
This submission builds under Windows only. Updates for the Linux build are in progress.
New value:
Unit tests for Server pass (380 OK). Unit tests for Web Extension 4/934 errors.
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
