[mapguide][MG368][New] Server reports negative operation times occasionally
Bruce Dechant
bruce.dechant at autodesk.com
Wed Aug 23 15:49:39 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG368
Type
Defect
Artifact ID
MG368 (Server reports negative operation times occasionally)
Reported by
Bruce Dechant
brucedechant (bruce.dechant at autodesk.com)
New artifact details:
- Version set to new value
1.0.1
- Artifact Status set to new value
New
- Operating system set to new value
All
- Component set to new value
Server
- Target milestone set to new value
1.1.0
- Subcomponent set to new value
Core
- Artifact created
- Steps to Reproduce set to new value
While running the server under load, or a few minutes after running an extended load test, view the operation times of the server using either the Web Admin application server status pages, or the API test pages.
Expected observation: All time values to be positive numbers.
Actual observation: Times are occasionally displayed as negative numbers.
- Summary set to new value
- Defect Severity set to new value
Low
- Priority set to new value
P3
- Description set to new value
The server will report negative operation times occasionally. This is because of an overflow error. The server is storing milliseconds for operation time when it really only needs to store seconds.
- Platform set to new value
All
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
