[mapguide][MG372][New] Server does not exit cleanly when exception occurs during st...
Ronnie Louie
ronnie.louie at autodesk.com
Fri Aug 25 18:24:50 EDT 2006
You can view the artifact detail at the following URL:
https://mapguide.osgeo.org/servlets/Scarab/id/MG372
Type
Defect
Artifact ID
MG372 (Server does not exit cleanly when exception occurs during startup)
Reported by
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
New artifact details:
- Artifact created
- Description set to new value
When running as a service, the timing of events can lead to a uncaught null pointer when stopping the worker threads. This pointer needs to be checked for null before it is used.
- External ID set to new value
803934
- Artifact Status set to new value
New
- Version set to new value
1.0.1
- Resolution Description set to new value
Check for null pointer before attempting to use it.
- Summary set to new value
- Steps to Reproduce set to new value
When running as a service, an exception thrown during initialization will cause the server to shutdown.
Expected result: server exits cleanly
Actual result: Application error in event log
- Subcomponent set to new value
Core
- Priority set to new value
P3
- Defect Severity set to new value
Medium
- Component set to new value
Server
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
