[mapguide][MG372][Modified] Server does not exit cleanly when exception occurs during st...
    Ronnie Louie
    ronnie.louie at autodesk.com
    Fri Aug 25 18:29:07 EDT 2006
You can view the artifact detail at the following URL:
    https://mapguide.osgeo.org/servlets/Scarab/id/MG372
Type:
Defect
Artifact ID:
MG372 (Server does not exit cleanly when exception occurs during startup)
Modified by:
Ronnie Louie
ronnielouie (ronnie.louie at autodesk.com)
The following modifications were made to this artifact:
-- Testing Notes set to new value:
Server unit tests: 380/380 tests OK
-- Artifact Status changed:
Old value:
New
New value:
Resolved
-- Resolution set to new value:
Submitted
-- Build set to new value:
178.32
This message was automatically generated by Project Tracker.
More information about the Mapguide_issues
